Group: DynoMotion Message: 972 From: Allen Date: 3/14/2011
Subject: Kill thread via NotifyPlugin
Can I call a script command like this in a user program:
Kill(3);
I need to kill that thread if RESET is active in mach3. I placed this command in my notify user program and get an error "undefined symbol "Kill" "
Group: DynoMotion Message: 973 From: Tom Kerekes Date: 3/14/2011
Subject: Re: Kill thread via NotifyPlugin
Use
PauseThread(3);
to "Kill" a thread.  But if possible it always better to have a thread clean up and terminate itself.
from KMotionDef.h
// M U L T I - T H R E A D S U P P O R T
void
StartThread(int thread); // starts a downloaded program at it's entry point
void
PauseThread(int thread); // stops a thread from executing
int
ResumeThread(int thread); // resumes a thread after a pause
void
ThreadDone(void); // call to terminate current thread
Group: DynoMotion Message: 974 From: Allen Date: 3/14/2011
My problem is that when I press reset in Mach while the machine is homing the thread continues to run in the background. I used the PauseThread command (which does stop the thread from running) as well as the updated plugin that stops jogging if the reset is pressed. If I open the Axis window in KMotion axis #4 (my slaved axis) is still moving even though the thread has been killed and mach is in reset mode.
I understand the best way is to not handle estop via software, etc. and that is fine and ultimately I will be killing the drives with an external relay but that doesnt help me to completely kill all aspects of the homing routine running in the background.
Thanks for your help,
Allen
Allen
> Use
> PauseThread(3);
> from KMotionDef.h
> // user threads are numbered 1 .. nvoidStartThread(intthread); // starts a
> downloaded program at it's entry pointvoidPauseThread(intthread); // stops a
> thread from executingintResumeThread(intthread); // resumes a thread after a
> pause voidThreadDone(void); // call to terminate current thread
> From: Allen <agray@...>
> Sent: Mon, March 14, 2011 11:19:03 AM
> Subject: [DynoMotion] Kill thread via NotifyPlugin
> Kill(3);
Group: DynoMotion Message: 975 From: Tom Kerekes Date: 3/14/2011
Hi Allen,
Yes once a motion is initiated, the motion will continue regardless of the state of the thread.
I think the best solution is to add code in the Home routine to watch for Mach3 Reset.  The home routine can monitor the Amplifier Enable I/O bits and if it sees one disabled then it should stop all motions and terminate itself.  If you aren't using Amplifier Enables we could add a Virtual Bit (Bit48) that we could use as a flag to the Home routine.
I believe we worked on a similar issue before and added code to watch for external EStop and to stop all motion with the following code:
// check for estop
if (ReadBit(133))
    Jog(0,0.0);
// StopMotion
    Jog(4,0.0);
// StopMotion
    Jog(1,0.0);
// StopMotion
    Jog(3,0.0);
// StopMotion
    printf(
"Homing Aborted!\n");
We can change that to stop and terminate on external estop OR Mach3 Reset by doing
// check for estop or Amplifier Disabled
if (ReadBit(133) || ReadBit(48))
    Jog(0,0.0);
// StopMotion
    Jog(4,0.0);
// StopMotion
    Jog(1,0.0);
// StopMotion
    Jog(3,0.0);
// StopMotion
    printf(
As a side note, hitting RESET in the new plugin will cause all axes in the coordinate system (X,Y,Z) and stopping the master axis would normally also indirectly stop any slaved axes.  But until homing (and squaring) is complete the axes are not yet slaved together which is why the second X axis never stops.  But regardless, changing the home routine to watch for RESET  and stop should solve the issue.
Group: DynoMotion Message: 976 From: Allen Date: 3/15/2011
How exactly do I tie the virtual bit to mach3's reset? I enabled one of the "Enable" signals in Ports&Pins and set it up for Port1 Pin48. As I toggle the RESET button in mach I use the console in KMotion to ReadBit48 but the state does not change.
Allen
> Hi Allen,
> of the thread.
> // check for estop{
>     Jog(0,0.0); if(ReadBit(133))// StopMotion    Jog(4,0.0); // StopMotion
> Jog(1,0.0); // StopMotion    Jog(3,0.0); // StopMotion    printf(
> }"Homing Aborted!\n");    return;
> doing
> // check for estop or Amplifier Disabled{
>     Jog(0,0.0); if(ReadBit(133) || ReadBit(48))// StopMotion    Jog(4,0.0); //
> StopMotion    Jog(1,0.0); // StopMotion    Jog(3,0.0); // StopMotion    printf(
>  "Homing Aborted!\n");    return;As a side note, hitting RESET in the new plugin
> Thanks
> Sent: Mon, March 14, 2011 12:10:12 PM
> Subject: [DynoMotion] Re: Kill thread via NotifyPlugin
> is in reset mode.
> the background.
> Allen
> Allen
> > Use
> > PauseThread(3);
> >up
> > from KMotionDef.h
> > From: Allen <agray@>
> > Kill(3);
> >in
Group: DynoMotion Message: 977 From: Tom Kerekes Date: 3/15/2011
Hi Allen,
I just tried it and it works for me.  I used Config | Ports&Pins | Output Signals | Enable1 | Enabled Pin 48 Port 1 ActiveLow=no
You might try it with bit 47 which is a KFLOP LED.
Do you have something else outputting to Bit 48?
Group: DynoMotion Message: 978 From: Allen Date: 3/15/2011
OK, that worked. Just had to change it to !ReadBit(47) though. I did have something on 48 but I also tested with 40 and still didn't work. Does now though, thanks :)
> Hi Allen,
> From: Allen agray@...|
> Sent: Tue, March 15, 2011 7:04:31 AM
> does not change.
> Allen
> > Hi Allen,
> >state
> > of the thread.
> >you
> > // check for estop{
> >StopMotion
> > doing
> >Jog(4,0.0); //
> >StopMotion    printf(
> >plugin
> >(and
> > Thanks
> >(which
> >mach
> > is in reset mode.
> >that
> > the background.
> > Allen
> > Allen
> > > Use
> > > PauseThread(3);
> >clean
> > >up
> > > from KMotionDef.h
> > > Kill(3);
> > >in
